sno's avatar
sno
Guide
Dec 23, 2020
XR500 DHCP Lease renewal causes connection drop
Hello, my lease renews every 24 hours, at which time I lose connection for about 30 seconds even though my ip never changes.  Is there a resolution for this issue?  My other Nighthawk R7000 router do...
  • sno's avatar
    sno
    Jan 07, 2021
    Reporting back as I said I would, downgrading to firmware version 2.3.2.22 fixed my DHCP lease renewal connection drop issue for anyone that's having the same issue I recommend trying this.
    Cheers
