sno
Dec 23, 2020Guide
XR500 DHCP Lease renewal causes connection drop
Hello, my lease renews every 24 hours, at which time I lose connection for about 30 seconds even though my ip never changes. Is there a resolution for this issue? My other Nighthawk R7000 router do...
- Jan 07, 2021
Reporting back as I said I would, downgrading to firmware version 2.3.2.22 fixed my DHCP lease renewal connection drop issue for anyone that's having the same issue I recommend trying this.
Cheers
Netduma-Fraser
Jan 08, 2021NetDuma Partner
Thanks for the feedback, Netgear are collecting data from users having the issue so hopefully that will be fixed shortly.
sno
Jan 08, 2021Guide
Thanks for the response, instead of looking at user data, they may want to look at what was changed from 2.3.2.22 to 2.3.2.32. User data from alot of the later versions may not be so helpful due to the amount of changes made beyond that version. Whatever this bug is happened with the .32 update and propagated all the way up through beta.
.22 to .32 is an incremental update, it's probably something small that happened.
That's my 2 cents, thanks again.
- Netduma-FraserJan 08, 2021NetDuma PartnerThank you for the input, I've passed that onto Tim as well.
- snoJan 08, 2021Guide
Thanks, if you hear of a resolution I would appreciate a response to this thread. I would like to get off of this firmware version at some point.
I appreciate you responding and escalating the issue.
-Jordan
- snoFeb 07, 2021Guide
- Netduma-FraserFeb 09, 2021NetDuma PartnerPort 80 is required for web browsing by all devices so it's likely UPnP even if it's not showing has opened this for devices. It is not a good idea to port forward 80 either as it could negatively impact other devices.
