sno
Dec 23, 2020Guide
XR500 DHCP Lease renewal causes connection drop
Hello, my lease renews every 24 hours, at which time I lose connection for about 30 seconds even though my ip never changes. Is there a resolution for this issue? My other Nighthawk R7000 router do...
- Jan 07, 2021
Reporting back as I said I would, downgrading to firmware version 2.3.2.22 fixed my DHCP lease renewal connection drop issue for anyone that's having the same issue I recommend trying this.
Cheers
sno
Feb 07, 2021Guide
Netduma-Fraser
Feb 09, 2021NetDuma Partner
Port 80 is required for web browsing by all devices so it's likely UPnP even if it's not showing has opened this for devices. It is not a good idea to port forward 80 either as it could negatively impact other devices.
