Untug
Feb 10, 2021Tutor
xr500 Disappointing All Around
I have a modest network at home, 5 Computers wich 2 of them are game servers. I host a PC gaming community that supports almost every country around the world. I have host 2 server that run game se...
xstefen
Feb 15, 2021Aspirant
You and me both, and Netgear support is absolutely laughable, it may me more effective if it didnt exist at all. Oh well right, just another $250 slap to the face. What can ya do...
Netduma-Fraser
Feb 15, 2021NetDuma Partner
Untug here you are: https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0
xstefen if there are any issues you're having make a new post and we'll be happy to help you.
- UntugFeb 15, 2021Tutor
Netduma-Fraser I update the firmware, I have running right now. I will report back to this thread to you as soon as I am able and have givin it a good once over and some network traffic has gone through it ;).
Here are some initial results from your DUMAOS Dashboard with the beta firmware:
Speed Test from Speedtest.net
https://www.speedtest.net/result/10934950042.png
Speed Test From DUMA
Not sure whats going on with the DUMAOS Connection Benchmark but yea.. Figured I would give you that info. No apps crashing as of yet. Will work on replicating the issues before with my community members and clients that were having connection issues. A fair go would be atleast 24 hours. Ill give you a more detailed report then.
Just some side comments:
- DumaOS seems more responsive (ThumbsUP)
- Control Over GeoFilter is much more robust, although I dont use it I am hoping it wont cause that odd connection issue. (time will tell)
- Traffic Controler is a good edition (will this allow portforwarding for subnets?)
- Overall a more polished and responsive feel.
Figuerd I would list the positives as well =D
Is this the XR1000 OS? =D
- Netduma-FraserFeb 15, 2021NetDuma PartnerConnection Benchmark we are aware of, we'll get that responding more accurately but as you can see it isn't restricting your speeds to that which is good. Thanks for the positives, always nice to here! Do make sure to do a factory reset first if you encounter any issues as it will clear any old low level code from the previous version. Traffic Controller is just for allowing/denying certain devices/traffic so nothing to do with port forwarding.
Thats what i figured, I just checked it out. =( was hoping for that. Would be nice to be allowed to set a subnet.
I assume that this OS is for the XR1000?
And yea its not effecting anything. I just assumed it was to one of your own servers or somthing. Just fiugred I would mention it..
Already did a factory Reset =D, its fresh.
