Goretech
Apr 12, 2018Guide
XR500 disconnected every morning
I just got the XR500 6 days ago and so far each morning I goto my wired desktop and its disconnected. I can't access the UI of the router or the internet. A quick power button off/on, then some wait...
- Apr 22, 2018
Currently, I believe setting QoS to always has stopped it from causing disconnects. I have another issue but will post in a new thread.
Netduma-Fraser
Apr 12, 2018NetDuma Partner
Does this occur for all devices or is it only for your desktop? Is there anything specific happening on the network during the night? If you do a factory reset and then monitor it does it happen again?
- GoretechApr 12, 2018Guide
I just did a factory reset. I will monitor overnight and let you know. I will test all devices before rebooting if it happens again.
Thanks,
-G
- JasonNApr 12, 2018NETGEAR Employee Retired
Hi Gioretech,
Thank you for the response!
Please keep us updated. :]
- Jason N
- GoretechApr 14, 2018Guide
Since the default reset I have not had any issues. One thing I noticed during the reset was I had named my WIFI the same as the old router and a lot of devices were getting denied due to wrong password. Not sure if this caused the router to freak out over night but during the re-setup I changed the name.
-G
