David_allen09
May 15, 2020Aspirant
XR500 Disconnecting every day
Lately I have been getting disconnected from my router. This occurs after every DHCP lease event, which also shows several DOS attacks. But again, this only happens during the DHCP lease event. A tho...
Netduma-Fraser
May 16, 2020NetDuma Partner
If you provide a static IP/IP reservations for some of the affected devices in LAN Settings do you still see the issue on those devices?
David_allen09
May 16, 2020Aspirant
Seeing how every DHCP lease event causes the router to crash and reboot, I dont think setting static IPs is going to fix that. For some reason, everytime the Lease renews, I suddenly get a ton of DOS attacks and a router shutdown and reboot
- Netduma-FraserMay 16, 2020NetDuma PartnerWait so the entire router reboots itself when this happens? If that's the case try plugging the power directly into a wall outlet, if it continues try another power adapter. If it's still a problem then I would recommend getting the router replaced.
- David_allen09May 16, 2020Aspirant
Short of wiring the power supply to the wall, that also has been done. I assue you that if i buy another router, it will never be a Netgear router. This is unacceptable.
I will say that finally, after 17 factory resets, I dont seem to have any issues. But I also dont want to use the QOS or any other feature because it will crash again.
