Skriker
Jan 31, 2020Tutor
XR500 Disconnects on lease expiration from xfinity gateway in bridge mode
Question: The XR500 disconnects all devices when the WAN lease is renewed or static IP's are assigned. Is this just the way the product is designed? Do I need to buy a different router to fix this is...
- Feb 10, 2020
.40 alone did not resolve my issue, but this hotfixed image from DumaOS sure did.
V2.3.2.40-C424a Source: https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
Skriker
Jan 31, 2020Tutor
I have reverted to .40. I'll report back on the result.
Netduma-Fraser
Feb 04, 2020NetDuma Partner
Sorry to hear you're having this issue. It is something we are aware of and trying to resolve. It's unfortunate the Xfinity lease is so short as otherwise it would only happen once per day which is when the XR renews the lease. Downgrading is a good idea, if that doesn't work then if you have a spare router you could put between the gateway and XR then put the XR in that routers DMZ then that may resolve it.
