usermac
Jul 29, 2018Luminary
XR500 Displaying The Incorect Ethernet slot light
When I plug an ethernet cable into say ethernet slot 1 the router will indicate that it is in slot 4. The numbering is back to front. This is really anoying how do you get the router to display corre...
- Jul 31, 2018That was around the time the issue occurred if I remember correctly. Start a ticket with support and it should get bumped up.
Netduma-Fraser
Jul 29, 2018NetDuma Partner
It's hardware so if it really annoys you then you can get it replaced. Though there is 0 impact on performance.
