usermac
Jul 29, 2018Luminary
XR500 Displaying The Incorect Ethernet slot light
When I plug an ethernet cable into say ethernet slot 1 the router will indicate that it is in slot 4. The numbering is back to front. This is really anoying how do you get the router to display corre...
- Jul 31, 2018That was around the time the issue occurred if I remember correctly. Start a ticket with support and it should get bumped up.
usermac
Jul 31, 2018Luminary
Hello I got a replacement from Amazon and that too has the same issue. Spoke to Netgear suport and they told me this unit is fairly new as it was built Febaury 2018 and they have never heard of this problem.I find it really anoying that a £250 router has missed the quallity control dept and in my case twice. As I have already recived a replacement from Amazon they wont replace it again but only other a refund in full which I am consdering unless netgear can send me a replacement.
Netduma-Fraser
Jul 31, 2018NetDuma Partner
- usermacJul 31, 2018Luminary
Just to confirm Netgear suport is sending a replacemnt and they said they would make sure it was a new unit that is not affected by this issue. Thanks for the quick replies :smileyhappy:
