Titanspark
Nov 11, 2024Aspirant
XR500 Dropping Connection Once A Day
I have been using this Netgear XR500 about 6 months now and almost every single day it drops internet connection. I've read about this issue when trying to fix it a couple months ago and it seems fai...
Netduma-Fraser
Nov 12, 2024NetDuma Partner
In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 4 minutes and see if that stops the disconnects.
Titanspark
Nov 15, 2024Aspirant
Hi,
Been a couple days now and I can confirm unfortunately that has not fixed the issue. Is there anything else I can do?
Thank you for your help.
- Netduma-FraserNov 16, 2024NetDuma PartnerAssuming you have given all the devices a reserved IP, disable DHCP entirely and see if that helps please.
