Nightfall1293
Apr 19, 2019Aspirant
XR500 Dropping Connection
So I have posted several posts here to help figure out this issue. I thought I was experience a DoS attack at first, then, thought it was an ISP issue. However, I have isolated the issue. All day I c...
schumaku
Apr 20, 2019Guru - Experienced User
The DoS are just side effects and false positives from established connections which are lost unexpectedly - e.g. because of the systems lost the connection to the router and the Internet.
Beyond, afraid no idea what is causing the problem...
- Netduma-FraserApr 21, 2019NetDuma PartnerI just responded to your other topic but based on the new information this sounds like it could be based on standby mode. Do you keep your TV in a standby mode? If so can you shut it down properly, then try again by turning it on from a full shutdown, does that resolve it?
