Nightfall1293
Apr 19, 2019Aspirant
XR500 Dropping Connection
So I have posted several posts here to help figure out this issue. I thought I was experience a DoS attack at first, then, thought it was an ISP issue. However, I have isolated the issue. All day I c...
schumaku
Apr 20, 2019Guru - Experienced User
The DoS are just side effects and false positives from established connections which are lost unexpectedly - e.g. because of the systems lost the connection to the router and the Internet.
Beyond, afraid no idea what is causing the problem...
Netduma-Fraser
Apr 21, 2019NetDuma Partner
I just responded to your other topic but based on the new information this sounds like it could be based on standby mode. Do you keep your TV in a standby mode? If so can you shut it down properly, then try again by turning it on from a full shutdown, does that resolve it?
