Nightfall1293
Apr 19, 2019Aspirant
XR500 dropping internet connectio
So I have been using this router with a netgear modem for a couple months now and all of a sudden it started having issues where it would just disconnect everything on the network
[DoS Attack: ...
Netduma-Fraser
Apr 21, 2019NetDuma Partner
Don't worry about the DoS attacks, they won't be causing it. Checked the IPs, it's Facebook and Spectrum (who I assume is your internet provider).
How often does this occur on average? Once a week/day? Multiple times per week/day? Set static IPs for your devices and see if that resolves it please.
Nightfall1293
Apr 21, 2019Aspirant
It ended up being a corroded coaxial cable line that was causing not enough power upstream. ISP sent out a tech to replace the cable since then everything has been perfect
- Netduma-FraserApr 21, 2019NetDuma PartnerGreat to hear that, thanks for the update!
