ICleverUserName
May 21, 2019Tutor
Xr500 dropping internet connectivity to wired devices only roughly every 18 hours
ok so like the title says, im having an issue with my xr500 reguarding dropping internet connectivity to wired devices only. It happens once a day, and a simple power cycle solves the problem. Its w...
- May 21, 2019
This has been reported to Netduma a lot of times. They came out with a hotfix firmware that should solve this. If it doesn't for you, putting a network switch in between the wired devices seems to fix it. Firmware here: https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
MikeCompetillo
May 21, 2019Guide
- ICleverUserNameMay 21, 2019Tutor
I have an S8000 switch that I used to use for my game room but i have since removed it from the network because the router in now located in the game room. Your recommendation is to install this firmware and add the switch or just go the hotfix route? Thanks for the replies btw
- MikeCompetilloMay 21, 2019Guide
You should try the hotfix first. If that doesn't help, add the switch. The hotfix solved my wired disconnections.
- ICleverUserNameMay 21, 2019TutorWill do thanks. I’ll add one observation as well. I was just home and all wired devices were disconnected so before the power cycle I checked the ip addresses assigned to them. NONE of the wired devices had an up address assigned via DHCP. Would this be an indication of the problem Netduma is trying to alleviate with this patch?
