Santamaria789
Apr 22, 2020Guide
XR500 dropping internet
Hello, earlier today my internet dropped. I rebooted my router and modem which fixed the problem for a few hours. Internet dropped again but I get access if I hook up directly to my modem so my router...
Apr 23, 2020Guru - Experienced User
Firmware on the router?
What modem are you connected to?
Santamaria789
Apr 23, 2020Guide
I’m running the latest firmware, at least that’s what the router says when I do a search. I’m at work now and can’t check the version. My modem is an Arris SB6141. I did a factory reset last night and that fixed it but I feel like that might be a bandaid fix. From what I can see in older posts, this has been an issue with past firmwares and should have been resolved.
