Slippin_Jimmy
Feb 24, 2020Aspirant
XR500 dropping LAN and WiFi connection when dloading on PS4 rest mode
Having an odd issue with my XR500. On software version: V2.3.2.56. I'm in Australia we are connected to the NBN via FTTC, and the router is connected to a NCD device which is Netcomm NDD-0300(This is...
Netduma-Fraser
Feb 25, 2020NetDuma Partner
It is odd that DHCP off would fix it but only momentarily. This reminds me of an issue awhile ago where the sort of WOL (wake on LAN) doesn't work correctly all the time. Do you have a switch that you could put between the router and the console to see if it can continue to download when in rest mode?
