drcheesenipz
Feb 14, 2020Guide
XR500 dropping lan connection on ethernet port 2
Has anyone had any issues with the router dropping connection specifically on lan port 2? My current version of DumaOS is V2.3.2.56, and only a reboot fixes the port 2 connection. I have changed out ...
drcheesenipz
Feb 14, 2020Guide
Just to clarify, the lan ports don't match up with physical numbering under Device Manager's table view. Looks correct under Statistics menu.
- Netduma_AlexFeb 17, 2020NetDuma Partner
I believe that the incorrect port numbers was a known problem with early units. Newly manufacturered units don't have this problem.
As for why port 2 isn't working, it sounds like a hardware issue. I've never come across just one port suddenly not working.
- drcheesenipzFeb 17, 2020Guide
I have been observing it a bit more. Moved the Roku back to port 2, and it hasn't dropped once all day yesterday, even had the xbox on that port for a few hours without issues :smileyfrustrated:. I'll keep a closer eye on it since I still have until June for warranty, but it hasn't been cosistently dropping day in and day out yet to confirm anything.
As for Device Manager misrepresenting port numbers, since it is an early unit issue, should I just live with it or open an RMA case?
- Netduma_AlexFeb 18, 2020NetDuma Partner
Up to you... Since you've got one port that's not working, it might be worth RMA'ing.
