Vinotauro
Dec 09, 2018Guide
Xr500 dropping ps4 game and party connection
Hi guys, this is a great router.... When it's working right. This only seems to happen at night (somewhere between 8pm and midnight) I'll be in a party chat and a game when the router will randomly dr...
Dec 11, 2018Guru - Experienced User
Did you get NAT filter to OPEN?
I would try with a different router to see if same thing happens. This should rule out the ISP services. Do you have a prior router handy by chance?
Sounds like something is happening with the XR router. Possible FW issue. Would need to try something else or a different XR router.
Vinotauro
Dec 11, 2018Guide
Yup tried my old R6700 no issues
- Netduma-FraserDec 11, 2018NetDuma PartnerI would contact Netgear support so they can get you to capture the debug logs when it occurs then they can see what the issue is.
- VinotauroDec 11, 2018Guide
- Netduma-FraserDec 11, 2018NetDuma PartnerI'd find out on the Device Manager which device that MAC address belongs to and then give it a static IP to prevent that happening
- VinotauroDec 11, 2018GuideI'm pretty certain that's the routers ip
- VinotauroDec 11, 2018GuideWhen you say static, you mean reserving the ip right?
- Netduma-FraserDec 11, 2018NetDuma PartnerThat wouldn't be the router IP, it's likely 192.168.1.1 and .4 is a device. Yes reserving an IP
- VinotauroDec 11, 2018GuideMy mistake but yes I've actually added all connected devices to a reserved ip to see if it helps
