pAckmAn4000
May 07, 2020Aspirant
XR500 dropping wifi connection every 3-5 minutes
My XR500 dropping wifi connection every 3-5 minutes causing my laptop to reconnect all the time. What's interesting is that it happens for 1 device only - all other devices in home (2 phones + 2 ...
pAckmAn4000
One small addition - it happens on both 2.4Ghz and 5Ghz. And changing wifi channels doesn't help.
Conection type - PPPoE, via ISP's optic fiber receiver.
- FURRYe38May 07, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last update?
- Netduma-FraserMay 07, 2020NetDuma PartnerGive the laptop that you're experiencing the issue on a static/reserved IP in LAN Settings - use the same IP from the Device Manager that it is getting for ease. Does it still continue after this?
