bigmickjeans
May 18, 2020Aspirant
Xr500 drops connection A LOT like, holy crap
I've been searching the forums for an answer and trying all sorts of stuff but this thing just cannot keep a connection, sometimes going in and out half a dozen times in a hour. Sometimes stays on for...
Netduma-Fraser
May 19, 2020NetDuma Partner
I think this will probably require you to get a replacement as it sounds faulty. However, try plugging directly into a wall outlet if you're using an extender. If it still occurs then try using another adapter of the same voltage.
