Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Basiu
Jun 17, 2018Aspirant
May I also have this firmware? my XR500 keeps losing internet connection on my ps4 pro would like to give it a try thanks
Netduma-Fraser
Jun 17, 2018NetDuma Partner
I've sent you a PM with the firmware
- UND3RXOATHJun 17, 2018AspirantSame problems here. Dropped WiFi :(
- Netduma-FraserJun 17, 2018NetDuma PartnerSent you firmware via PM
- StevecookSep 04, 2018ApprenticeHaving same issue. Can you send me the firmware.
- M-HafeezDec 03, 2018Tutor
Please Send me as well. Thanks
