Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma-Fraser
Jul 02, 2018NetDuma Partner
Hiredgun, as per PM will try to get XR450 version for you.
vpoffice, its based on the previous firmware so will miss the features/fixes from the current version. I've sent it to you in a PM. It should however be a part of the next firmware.
Jessed
Jul 02, 2018Aspirant
Can I get the firmware too please
- Netduma-FraserJul 03, 2018NetDuma PartnerI've sent you a PM with the firmware Jessed
- Phoenix1776Jul 03, 2018Tutor
The XR500 has started dropping internet connections about 2-3 times a day; no pattern on timing. As someone who regularly works from home the lost connection is happening at really bad times. Using:
- Netduma-FraserJul 03, 2018NetDuma PartnerI've sent you a PM with the firmware Phoenix for this issue.
- DrDeanoJul 03, 2018Aspirant
Having similar random internet drops.
I don't have XBox, but I have around 40 devices on my network; PCs, Macs, Nvidia Shield, Echos, Ecobees, etc... Roughly 40/60 wired to wireless.
Internet seems to be out in the morning usually and reboot fixes it. Would appreciate a solution to this.
- Netduma-FraserJul 03, 2018NetDuma PartnerI've sent you a PM Deano with the firmware to try
Installed the firmware, thank you.
How necessary is it do a factory reset with this test? Should I turn off the firmware auto update since this is an older firmware?
Thanks for the quick response!
- Netduma-FraserJul 03, 2018NetDuma PartnerI would advise it if you don't mind to ensure no legacy issues from previous firmware. That's up to you. The fix will be included in the next update as far as I know.
