Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
FMSMITH91
Jul 07, 2018Aspirant
Been getting random disconnects. Did a factory reset on it but it just happened again. Can I get the new firmware as well. Running V2.3.2.22 right now.
- Netduma_JackJul 08, 2018NetDuma PartnerMessaged both of you with the firmware. Let us know in this thread if it does not work.
- Idontknow235Jul 08, 2018Aspirant
I downloaded the Firmware but I wanted to ask if you possibly knew when the newest update that will fix this will be?
- Netduma-FraserJul 08, 2018NetDuma PartnerDon't have an ETA on that.
