Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma-Fraser
Jul 13, 2018NetDuma Partner
I've sent you a PM Randy!
DrDeano
Jul 13, 2018Aspirant
Update:
The firmware you sent in PM fixed the disconnect problem; but I forgot to turn off auto-update.
My router pulled the official firmware at some point last night (could not tell from the logs) and sure enough, I lost internet. The interesting thing was that rebooting did not fix it and even reverting back to the firmware you sent me didnt instantly give me internet access.
I use my router as the primary modem connected directly to the ONT. I dealt with IP lease issues while I was setting everything up when I first bought the router. It almost seems like whatever plagues the official firmware has to do with the ISP seeing an unknown router and being unable to obtain a lease, not unlike if you tried to switch modems without releasing the IP first.
I eventually got internet back, but I think it took as long as my ISP to release and renew the IP on their end (2 hours)
Hope this helps... I would have expected a company like Netgear to have this problem solved and official firmware available to fix it much sooner.
-Dean
- Netduma-FraserJul 13, 2018NetDuma PartnerI think that might just be a coincidence as the common theme among people is a console in instant on mode. Factory reset on the one I gave you again and continue to monitor. I've raised it back up to Netgear and Xbox contact to get it resolved for the rest of people with issues.
- DrDeanoJul 13, 2018Aspirant
Just an FYI -
I do not have an Xbox and I was experiencing the drops.
- ericwgriffin194Jul 14, 2018TutorMy XBox console instant mode has been off for nearly a week. Firmware previously added. Internet drops have started up again.
2x today so far. Any other ideas?
