Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Nmercer
Jul 13, 2018Aspirant
Can I get the firmware update. My router is suddenly as of today dropping connection to all devices PC. Ps4. Fire tv and android and apple phones and nest equipment. Removed router from network and tested with equipment wired to cm1000 only . No issues. Will return router to best buy tomorrow if connectivity cant be resolved
- Netduma_JackJul 14, 2018NetDuma Partner
Hi NMercer - I will private message you the firmware link now. However, it sounds like you either have a general hardware fault or there is an issue with your line.
When the drop out occurs, is your modem still up and running?
- NmercerJul 14, 2018AspirantYea. The modem never loses connection. Only the router
