Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Scooby56
Jul 20, 2018Aspirant
Hi, I'm also experiencing issues with the XR500 disconnecting all devices. This often takes several reboots to get them working again and often the PS4 won't connect at all.
Could you send the firmware fix? Thanks
- Netduma_JackJul 21, 2018NetDuma PartnerI have just messaged you. Let us know if the issue continues. Hopefully not though!
- Clintb12Jul 21, 2018GuideI'm having the same issue... If you could please send me that firmware I'd like to try it also. I'm having disconnects once a day. I logged in via the Nighthawk app on iPhone and it said the internet was offline, I rebooted the router and it went back online. I have 3 Xbox One consoles and one X console, all wireless.
- Netduma-FraserJul 22, 2018NetDuma PartnerSent you a PM
