Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Clintb12
Jul 22, 2018Guide
Thank you. I’ll report back in a few.
vc1187
Jul 23, 2018Aspirant
Even with Fraser's firmware I am still having wifi instability on some devices. Wifi seems to stay connected on the device but data is not transmitted/received. Happens a lot when I am playing a mobile game that frequently sends/receives requests/responses from the game server. While there's no pattern on when it happens, eventually the game gets stuck sending or receiving and only resolves itself when I turn off wifi.
- Netduma-FraserJul 23, 2018NetDuma PartnerNetgear are looking into this further and I expect to have an update soon. Until then can you disable Instant on and automatic updates and see if that resolves it please
- vc1187Jul 23, 2018Aspirant
I do not have an Xbox or PS4.
Is Instant On only a feature of those consoles or is it a feature in the firmware of the XR500?
I also do not have Automatic Updates turned on for either my mobile device (iPhone 6 plus) or the XR500.
- Netduma-FraserJul 23, 2018NetDuma PartnerNo not on the XR500. Do you have any devices that you put to sleep and are set to update programs/apps automatically?
