Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
mnjk
Jul 28, 2018Guide
I have the firmware from Fraser installed but an still have "no internet" problems. What now?
Netduma_Jack
Jul 28, 2018NetDuma Partner
Do you mean you literally have no internet or that it keeps dropping out?
If no internet at all then I recommend a factory reset to go through the setup tour again.
If it’s just drop outs, could you describe exactly what happens. Does the whole router lose WiFi or power off? When this happens, can you connect to your modem to see if it still hasn’t Internet. It’s possible your whole line is dropping so it’s important to isolate where the problem is.
- mnjkJul 28, 2018Guide
Its erratic. Today my pixel XL was doing it. Many other devices were ok. Now the pixel is ok. Very inconsistent. It might be related to 5GHz connections but I am not sure, I have not studied it. That's your guys job. Send someone to my house or collect some log diagonstics on my router. Or send me a router that just -- works! I don't care to be part of you're product development program. I want something that just plain works! I got neough headaches in my life and that's why I paid top dollar for a router. All of these questions are an annoyance to me. I've spent more than 300 bucks of my time on this router's shortcomings. Please send me something that works under the warranty.
- RushalJul 28, 2018Guide
Just started having this same issue. Have had the router for about 2 months and now, every few hours it'll just drop internet. All devices, wired and wifi will say that they have internet but won't be able to get to anything. If I plug a computer directly into the modem, it has internet. If I then plug back into the router, the router can't get back online until it's restarted.
I've left it for several minutes and it'll never reconnect without a reboot.
Tried firmware: V2.2.1.10 and V2.3.2.22 same issue.
V2.3.2.22 started getting pretty bad when the net would go out and I would have trouble even loading the router pages, getting cross site frame errors.
- M-HafeezJul 29, 2018Tutor
Hello All,
I am having the same problem, XR500 dropping internet service while the internet light is blinking GREEN means it is connected to the ISP but only the service is down. This problem happened only after I change the router from the stock router ISP provided along with the connection. I have updated the firmware as well just the last nite but still same problem.
Moreover, "Guns Of Boom" game is not listed to be added as a priority traffic service. can anyone help me with that, please? I bought this router only for this game "Guns Of Boom" and I play on my Apple iPhone and Android phones and Tabs.
I need help to prioritize the traffic associated with this game otherwise the router is useless for me.
Hope to hear from you soon..
Regards: M.Hafeez
- Netduma-FraserJul 29, 2018NetDuma Partnermnjk, we don't control warranty/sending of replacements. Recommend you contact Netgear for that. I've sent you a PM if you want to do one last thing to help us.
Rushal, sent you a PM with the firmware.
M-Hafeez, sent you a PM with the firmware. Also look up the ports that your game uses and add them manually into traffic prioritization for you device.
