Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
wub901
Jul 31, 2018Guide
I have flashed the firmware fix however it seems to still be dropping the wifi I have reset it multiple times.
Netduma-Fraser
Jul 31, 2018NetDuma Partner
Sent you both another PM with newer firmware to try
- M-HafeezJul 31, 2018Tutor
Thank you so much dear, I will try this version tonite after office and will get back to you with the results in the morning.. :)
Netduma-Fraser wrote:
Sent you both another PM with newer firmware to tryRegards:
M.Hafeez
- Netduma-FraserJul 31, 2018NetDuma PartnerI didn't send it to you Hafeez. I still haven't heard feedback from firmware I provided previously.
you said that you send us both PM.. Anyways I downloaded again, I hope its the same so not gonna upload in the router. the feedback I will give you over weekend weekdays I go home late at night and then early morning leaving. sorry for delay.
but it seems okay becz a little time I use in nite, still i want to make sure while using longer time and will get you the sure outcome of the firmware you provided.
Regards:
M.Hafeez
- Netduma-FraserJul 31, 2018NetDuma PartnerYes it's worth it, I've sent you a PM MrIncognito.
I meant asharak and wub, the two posters above me. No worries let me know. - MrIncognitoJul 31, 2018Initiate
Thanks! I'll give it a try.
