Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Ombramortale
Jul 31, 2018Initiate
During the laset 2 days the router is just dropping randomly.
It was unable to reconnect (internet led=red), so an hard reset was required. I tried the reconnect/disconnect from the UI but it didn't work.
Never had any issues during the last year with the previous router (a cheap 4020 fritz).
Those 4-5 disconnections were during the downloading of Warcraft client (about 60GB), never experienced during the week before.
If a firmware is available i'dd like to try it (got the latest installed)
Netduma-Fraser
Aug 01, 2018NetDuma Partner
Sent you both a PM, let me know how you get on
- OmbramortaleAug 01, 2018Initiate
Installed, I'll let you know, gimme 2-3 days of testing
