Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
garaffatm
Aug 09, 2018Aspirant
I am experiencing the very similar issue and I am currently on the latest firmware. Can you PM me the firmware for additional testing?
- HomesliceDec 20, 2018TutorIve tried everything with the xr500 it seems to run a lot better with the old firmware but the usb 3.0 ports will cause the router to reboot when you use it so stay away.its sad that you pay $299 for a product that’s such a headache I’m gonna just return this because netgear support suck really bad I feel they don’t know there own products
- Netduma_JackDec 20, 2018NetDuma PartnerSorry to hear that. If you still own it, you could try downgrading the USB to 2.0 through the readyshare setting and see if that solves the problem.
- HomesliceDec 21, 2018TutorI got tried of downgrading and just took that router back and upgraded to the xr700 and so far so good. Router has not rebooted and my speeds is back to normal.
