Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Radiax
Aug 10, 2018Tutor
As I stated yesterday, I was up and running for over a week without any issues. I plugged my xbox one is last night, I watched a program from Plex off of the Xbox One. When I got off of work today, I have no internet and needed to restart my router. I have unplugged my Xbox one again.
Firmware: V2.2.1.10-DBG-XR356-180522a
- Danny80916Aug 10, 2018Luminary
still cant get a 4k movie to stream from my tv I am thinking its a comcast problem probably. I did notice something strange tho I have my modem then my router then off my router I have a nighthawk x6 in ap mode. My sony4k blu ray player can't find a internet connection if I have it going through the xr500 it says failed even hardwired ,but if i go wireless to the x6 that feeds the xr500.it I can get on the net
- Netduma_JackAug 11, 2018NetDuma Partner
Danny80916 - that is odd. Do all other devices have an Internet connection when going through the XR500?
- Danny80916Aug 11, 2018LuminaryYea expect my second blu ray player both can’t connect to Sony’s update page till I switch to my x6 then both work perfectly fine I just find it out that it will work through the x6 then through the xr500 but not directly on it .
Radiax - there's a newer version of the beta firmware. I will send this to you now via PM.
- RadiaxAug 11, 2018Tutor
Thanks! I will give the new one a try.
- psykixxAug 12, 2018Star
I've been running the beta firmware for a few weeks now, and all had been fine until yesterday. Had internet stop responding on all devices, despite the modem being fine.
Reboot of XR500 and EX8000 were required to restore internet connection.
Wouldn't mind trying the newer version too, thanks :-)
- Netduma-FraserAug 12, 2018NetDuma PartnerSent you a PM.
