Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma-Fraser
Aug 12, 2018NetDuma Partner
Sent you a PM, should hopefully resolve your issue
blackshirt40
Aug 12, 2018Guide
so i mostly play just leauge of legends, when i play hooked straitght to the moden im at 24 ping, when i go through router i am 27-28, not a huge difference, but still larger than it should i believe, but the more inportant thing is it feels really laggy, for example last hititng seems very dificult since the last router update. so my question is what should the amount of ping added be going through the router? i would guess less than one or around one millisencond not 3-4. would this new beta firmware help me? btw i have already changed all the settings i could think of to give league priority.
| Firmware version | XR500 V2.3.2.22 |
- Netduma-FraserAug 13, 2018NetDuma PartnerI've sent you the firmware in case you want to try it.
3-4ms increase should not make it feel really laggy in any way, especially considering you're under 30ms which is great! It could be the ethernet cables connecting the routers together that needs replacing. If you make a new topic that'll help and include your settings.- ZophopAug 13, 2018Initiate
Looks like I've started running into this issue over the last few days. The 5GHz network drops for most devices in the house and manually rejoining the network fails. The 2.4 band seems to remain live for devices with an existing connection but won't allow new devices to connect. A reboot brings things back to life though sometimes it's only for a few minutes, after a few reboot's it eventually sticks and things return back to normality.
- Netduma-FraserAug 13, 2018NetDuma PartnerI've sent you a PM with firmware to try.
