Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
tonirigatoni7
Aug 14, 2018Tutor
I am experiencing the exact same issue that others have mentioned. I noticed it occurs when both my PS4s are connected. I have factory reseted the router with no success. My router says I have the latest firmware. I did notice in the logs random DoS attacks so not sure if that is the cause. Any help provided is appreciated!
