Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Gardone8876
Aug 14, 2018Guide
Thanks for the firmware. No issues encountered currently. I am running verizon fios 1gb plan.
I am running three Linksys lapac2600 attached to the netgear xr500. This firmware fixed two belikin wemo mini that kept getting disconnected on reboot of router. still takes a good 5 minutes fior them to show up correctly, after reboot of router. When running speedtest.net i get a higher upload speed. Before i was getting 330 and now i consisntantly get 360-370. Download speed is more consistent. Overall the new firmware seems to work much better. Keep up the good work.
CommTech4
Aug 14, 2018Aspirant
I installed the firmware that you provided and it seemed to address the wireless portion of the problem but the ethernet connections still malfunction. To sum up the issue again, everyday the connections would still be there but without internet access. When this would occur, I would still be connected but unable to access the router menus until a reset had been completed. After installing the firmware that you provided, the issue doesn't happen over wifi and I'm also able to reach the router menu through those wireless connections. It would appear that my wired devices are showing a failing static ip although nothing is static. It also shows my ip address on these wired devices as random ip addressess and not those that were assigned through DHCP. This problem only seems to occur the next day and it will last until the router has been reset. I wanna get this fixed in the next few days before my return window expires and I'm stuck with a $300 brick.
