Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma-Fraser
Aug 19, 2018NetDuma Partner
Sent you a PM
SneakeyPetey
Aug 19, 2018Aspirant
I received the file but it wont open. Says 'the disc image file is corrupt". Went to folder > right click > mount. Am I following the steps correctly?
- Netduma-FraserAug 19, 2018NetDuma PartnerYou need to upload it to the router in Settings > Administration > Firmware Update
