Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
iTatze
Aug 22, 2018Aspirant
i get DHCP Lease Renewal multiple times per hour and i lose internet connection all the time whats up with this router not worth the money ...
Netduma-Fraser
Aug 22, 2018NetDuma Partner
@soupie, that could be to do with the WiFi. Disable Smart Connect and connect the TV to one of the individual bands instead.
I will also send you and iTatze and PM with firmware to try.
- iTatzeAug 22, 2018Aspirant
i have the newest Firmware 2.3.2.26 but it didnt change anything for me i will send the router back sad but i dont wanna deal with this anylonger
- Netduma-FraserAug 22, 2018NetDuma PartnerSorry to hear that, I'd suggest you factory reset first to ensure no legacy issues from the previous firmware and monitor it a bit longer before deciding to return.
- SneakeyPeteyAug 22, 2018AspirantSo I’m still having an issue even after updating the firmware. Routinely can’t connect on other, wireless devices, mostly on my iPhone.
This is frustrating and am ready to return the router. Anything else I can do?
- soupie68Aug 22, 2018Tutor
"Disable smart connect and connect the tv to one of the individual bands instead" Deer in the headlights look here... I'm a walk-me-through-these-steps type of person. Not real techy here. Not afraid to say that sentence makes very little sense to me and I don't know where to begin following those directions.
- Danny80916Aug 22, 2018Luminary
type in 192.168.1.1 or routerlogin.com i think left side settings click it then under setup wireless unclick the top box that says smart connect then apply. Then go to your tv scan for a wifi network and you should have two that have simliar names one might be say americanEagle then other americanEagle-5g use the 5g band if you can . If its a sony tv and you cant steam content its probably your isp I been going back and forth with sony for like a month trying to get mine to stream 4k I gave in and called my isp they admitted they could see a problem and need to look into it.
Thanks for using normal-person explanations. ;) We will try this and see what it does for us.
