Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Aug 23, 2018Guru - Experienced User
Try disabling MIMO and see. Is Smart Connect enabled?
So you have a 6180 modem??
B1ggSh00t3r wrote:
I've noticed issues as well. I have the Nest Cam (connected via WiFi) and get notifications every night (usually between the hours of 1AM and 6AM) that it went / was offline. It appears the disconnection is only for a few seconds.
I've haven't noticed any issues with other connected devices (via WiFi). I haven't determined if this is just an issue with the Nest Cam or if all WiFi devices.
It appears my 'Uptime' is currently at 2+ days, and the Nest Cam HAS disconnected from WiFi a few times within those two days. The Nest Cam is currently 1 of 38 devices connected (assigned IP addresses) to the XR500.
Any help / suggestions is greatly appreciated.
B1ggSh00t3r
Aug 23, 2018Apprentice
Smart Connect IS enabled. MIMO is enabled as well....
- FURRYe38Aug 23, 2018Guru - Experienced User
Try disabling MIMO first and test your cameras out...
This isn't the first time NEST has been known to have issues with there products...
- Netduma_JackAug 25, 2018NetDuma PartnerHi Shooter - I’m not sure on the current status but I believe there may be some issues with NEST products as another user reported it. I have a vague memory that he found using the Guest network might have helped but I’m not sure.
Sorry to not be more help - this is on the non-DumaOS side so my knowledge is not as high!
