Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
tonirigatoni7
Aug 25, 2018Tutor
In reviewing the logs I see an entry for new lease allocated. Is there a way to prevent this from happening every so often?
tonirigatoni7
Aug 25, 2018Tutor
Something to note, when I lose internet temporarily, the routeright turns orange for a brief minute then everything comes back up. It's like it's losing internet.
- Netduma_JackAug 25, 2018NetDuma Partner
That sounds like an Internet drop out rather than a router drop out. Next time it happens, try connecting to your modem directly (if you can) and see if the Internet is down on that too.
I would also recommend switching the Ethernet cable between your XR500 and your modem in case there's an issue there.
- tonirigatoni7Aug 25, 2018TutorI have Verizon fios so the modem is in the garage and the router is in the kitchen. Their modems are not like other cable providers like a Motorola docs3 router.
