Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Danimalski
Aug 30, 2018Tutor
Hello,
I am having the same issues, I wasn’t aware it was possibly my router as well until I came across this thread. I have the Netgear CM1000 modem and I also had the internet provider come out to trouble shoot this issue, they tried everything as well as switching the modem to their own and it actually dropped my speeds as well. My Netgear N900 worked like a charm I feel as it also had better signal strength. I live in a two story home so good connection is required. Please help, thanks!
