Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma-Fraser
Aug 31, 2018NetDuma Partner
Sent you a PM with firmware Dani, see if that resolves your issues.
Bulldaw6, you've only made 2 posts so it's very unlikely you have the firmware we're providing as its not publicly available. Double check the version numbers on the router and the one provided.
Bulldaw6
Sep 01, 2018Guide
So, I did update it, haven’t had a drop yet. If everyone’s internet is dropping, then why isn’t it available to the public????
- DanimalskiSep 01, 2018Tutor
Do you mind sharing the file with me? The one I was given was corrupted so it was a major bust. Also what program do you use to mount/unzip it?
