Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Qbisst
Sep 02, 2018Aspirant
I jut purchased this router yesterday and are experiencing the same issue, the WiFi works, but the devices that are connected through a wired ethernet connection stopped connnecting after a few hours. On the router, all the ethernet lights are flashing simultenously and have to reboot the router for the wired connections to work again. I have 2 Xbox ONEs connected, a PS4 and Phillips HUE light receiver. I am about to return this, all of the devices worked with my previous router(ASUS RT-3100). Please help.
- Netduma-FraserSep 02, 2018NetDuma PartnerSent you a PM with firmware to see if that resolves the issue. Also turn off instant on mode for the consoles.
- JgottaSep 02, 2018Aspirant
I didn't received a PM from you Fraser! :(
- QbisstSep 02, 2018Aspirant
Thanks, I'll try the firmware. With my previous router, I didn't need to turn off Instant On on my Xbox, only one device has that setting enabled, do I have to keep that setting disabled?
- Netduma-FraserSep 02, 2018NetDuma PartnerSent now Jgotta. I'd recommend so if the firmware doesn't work
- Ozzmanj1Feb 04, 2019Aspirant
May I please get a PM with a link for the xr500 firmware V2.3.2.26, thank you
- FURRYe38Feb 04, 2019Guru - Experienced User
You'll need to contact NG support to get a link. I would start here:
https://www.netgear.com/mynetgear/registration/login.aspx
