Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma_Jack
Sep 04, 2018NetDuma Partner
utebotz
Sep 04, 2018Aspirant
This issue appears to apply to the XR450 as I have the same issue. Is the firmware you are sending different than the version on the netgear downloads page? I currently have 2.3.2.22. I also have changed the setting on my xbox.
- FURRYe38Sep 04, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the XR router is connected too?
I have same router, no issues seen using most recent FW version using a NG CM1000r modem.
Have you tried the inital 1st version of FW as well?
- utebotzSep 04, 2018Aspirant
I am plugged into a Centurylink Actiontec DSL router. Issue did not exist until I introduced this new router into the mix.
- DanimalskiSep 04, 2018TutorAnyone know how to factory reset this back too day one original firmware? Seems the reset option under the admin cpanel reboots it and automatically updates it, smh.
Overall this router has been a nightmare, I am really debating on getting rid of it and trying out the Netgear X10, or just ditch it all and go with Ubiquiti. Anyone have experience, or suggestions? - B1ggSh00t3rSep 04, 2018Apprentice
Overall this router has been a nightmare, I am really debating on getting rid of it and trying out the Netgear X10, or just ditch it all and go with Ubiquiti. Anyone have experience, or suggestions?Administration >> Backup Settings >> Revert to factory default settings
- Danny80916Sep 04, 2018Luminary
go to the firmware page download the old firmware go to settings turn off autoupdate then try to upload the old one.
- FURRYe38Sep 05, 2018Guru - Experienced User
I believe he needs to download the older FW file from the web site and apply it.
I did this with my XR450...as a test.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the NG router in Router mode.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
- DanimalskiSep 05, 2018TutorI did the factory reset, everytime the router sets up it has the latest firmware that was loaded. I am ready to just ditch this whole setup and check out this company called, Ubiquiti. Looks more promising.
Did you first download the 1st released FW for the XR500 and apply it to the router? Just doing a Factory reset does not revert back to older version of FW.
Danimalski wrote:
I did the factory reset, everytime the router sets up it has the latest firmware that was loaded. I am ready to just ditch this whole setup and check out this company called, Ubiquiti. Looks more promising. - Netduma_JackSep 05, 2018NetDuma Partner
Danimalski - I have sent you the firmware
utebotz - unfortunately I don't have an XR450 equivalent. If you have an Xbox One, please could you perform a full power off as this will hopefully prevent you having any further issues. I believe the fix will be released publicly very soon, so this is just a temporary step.
I think I've sent the firmware to everyone but if anyone else needs the firmware please let me know
- DanimalskiSep 05, 2018TutorI haven’t download the first firmware for this router. I am using the Netgear cm1000 modem.
Try Downloading and installing the 1st version. Let us know if the new FW sent to you in PM works for you as well...
I'm using the CM1000 and my XR450 is working well with it.
Danimalski wrote:
I haven’t download the first firmware for this router. I am using the Netgear cm1000 modem. - StevecookSep 05, 2018ApprenticeThe firmware one of the guys sent me in a private message seems to have worked hasn't done it since I've installed it.
- Netduma_JackSep 06, 2018NetDuma Partner
Danimalski - when you get a drop out, does your entire Internet go down or just wired devices? It's possible you have an overall line issue. The next time it happens, try connecting to your modem and see if the Internet is still online.
If the Internet is online and working fine, but you are not getting a connection through the XR500, then we know the issue is there.
