Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Bulldaw6
Oct 08, 2018Guide
Yea, mine is different. Thought same thing when i switched. I’m assuming it’s ran by Coax to my home, then switches to and Ethernet cable. Ethernet comes directly into my home, I can connect directly to desktop or router, no modem involved. No shared network
Netduma-Fraser
Oct 08, 2018NetDuma Partner
clintb, do you have an Xbox in Instant On mode? If so switch it to energy saving mode, does that resolve the issue? If you have a PS4, power it down fully rather than leaving it in standby mode.
@Bulldaw, same for you, I assume you have a PS4? If so can you power it down fully and see if that resolves the issue.
Just so you have full knowledge other routers appear to have this issue so it's not exclusive to the XR500. This would indicate its an intrinsic issue with software the board uses so we have contacted the manufacturer and they are attempting to reproduce it. They have an idea what it could be so are helping us create another beta firmware to try, when that's available we'll provide it to people to try.
- Bulldaw6Oct 11, 2018GuideYes sir, but my biggest issue now is “Ethernet doesn’t have a valid up” WiFi works fine, but gaming computer does it after I restart or shutdown. I’ve tried all the tips and tricks online. Sometimes it resolves itself sometimes I have to reboot router & pc. It randomly drops internet with same trouble code. Plz help, I’ve already contacted isp, not on there end.
- Netduma-FraserOct 11, 2018NetDuma PartnerI haven't seen that error before, can you provide a screenshot please?
- Bulldaw6Oct 11, 2018GuideThis isn’t my photo, but it’s the exact “error”
I get. Currently not home - Netduma-FraserOct 11, 2018NetDuma PartnerAhh I see. A few possible causes I can think of:
Have you set a static IP on the PC itself without reserving the IP on the router?
Have you disabled DHCP on the router without reserving an IP for the PC? - Goofydad777Oct 11, 2018Aspirant
Question - Is it safe to upgrade to the latest firmware or only use the one that was provided by Netduma-Fraser?
- Bulldaw6Oct 11, 2018GuideI personally haven’t changed anything. I will check this evening
- RushalOct 13, 2018Guide
Still having issues with the internet dropping out and needing to restart about once a week. We do have PS4's in rest mode; not sure why that would matter. The last few times we've lost internet, it'll keep us connected to whatever game or stream we're watching but no new web pages, discord or anything else will work until the router is rebooted. Pretty odd.
- Netduma-FraserOct 14, 2018NetDuma PartnerAs mentioned before, its the keeping the device in a semi connected state that triggers the issue. Please power them down fully after use and see if the issue is resolved
- ASFxOct 14, 2018Tutor
Why is this topic marked "solved"? It is not solved. I have the latest firmware and my router still drops the internet connection connection 1-2 times per week. When it happens, all of the devices on my network lose internet access. Local network access still works though, I can connect to the router via the mobile app and reboot it, then my internet connection is fine again. This NEVER happened on my previous router. I figured i'd finally upgrade from the old airport extreme to something faster, but this XR500 has turned out to be a huge headache. This router has one job, and it doesn't seem to be able to do it without problems.
- Netduma-FraserOct 14, 2018NetDuma PartnerHave you tried the previous suggestions? I.e. disabling Instant On mode on the Xbox/fully turning off PS4 after use?
- RushalOct 14, 2018Guide
Is there any planned fix for the PS4/Xbox issue(if that even helps us, could be something else entirely)? We'll give it a try but it will take a week to see if it works, since it usually only goes out Saturday morning and evening. Being forced to power off the console and lose the auto-updates is pretty stupid when the whole marketing point of the XR500 is for gaming. Never had any other router ever give any **bleep**s about 90% of the things that the XR500 has given me greif over.
Right now it seems pretty sad that Netgear releases a new model router, with the issues this one has. Interesting that the reviews are so high on Amazon. Maybe not every one of these routers is a pain in the ass.
- Netduma-FraserOct 15, 2018NetDuma PartnerThere was a firmware update which was supposed to fix it, it hasn't worked for all users. They're investigating it further as well, with other teams. That's just a workaround right now will we wait for the fix. Other routers do have the issue also, not just exclusive to the XR500 but I understand your frustration.
- Danny80916Oct 15, 2018Luminary
If a beta firmware comes out I would like to try it. I am having a problem where my new pc will be trying to surf the web and the net goes out on it 100%. I am usually streaming netflix when it happens , netflix will keep working net will go out for 10-40 seconds on pc before I can get on a webpage as it is happening I can go to device manger in the software and see my tv is using 20mbs while my computer is using .003.
- ngearftardOct 15, 2018Luminary
Do you have a modem with an Intel Puma 6 or 7 chipset? If you have diificulty finding out, post the make/model here.
- raizorOct 15, 2018Initiate
I have the same issue where twitch streams will continue and LAN works but no websites will load. Checking "Disable Port Scan and DoS Protection" in the WAN settings seems to have fixed it but I haven't done extensive testing to confirm.
- Danny80916Oct 16, 2018LuminaryI have a sb8200 and cm1000
- Netduma-FraserOct 16, 2018NetDuma PartnerThat only occurs on your PC danny? I should think maybe QoS is not enabled correctly and the TV is saturating your connection
Yea only on computers it happens on my computer. Actually now that i am thinking about it only happens on wifi because my other computer has the same problem on wifi also.
- Netduma-FraserOct 17, 2018NetDuma PartnerCan you set QoS to 'Always' with both percentages set to 70% and share excess enabled for both Download and Upload on Bandwidth Allocation and see if the issue is resolved when your TV is using significant bandwidth please
- Danny80916Oct 17, 2018Luminary
My router is currently setup that way.
- Netduma-FraserOct 17, 2018NetDuma PartnerWhen it happens can you look at the log in System Information please and see if there is anything that could look like the issue please and post it here.
just a log full of Lan access from remote fallowed by all diffrent Ips.
- Netduma-FraserOct 18, 2018NetDuma Partner
Hi all, for those still experiencing this issue post here and we will PM you. We have a beta firmware available which should hopefully fix the issue. Danny, I'll send it to you now.
- smitheramOct 18, 2018Guide
Hello,
I have recently purchased the Nighthawk Pro XR500 which has the most recent firmware installed. Would it be possible for you to PM me the beta firmware mentioned?
Best Regards,
Shane
- Netduma-FraserOct 18, 2018NetDuma PartnerSent you a PM Smitheram
