Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
B1ggSh00t3r
Oct 25, 2018Apprentice
After purhasing the XR500 a few months back, I seemed to be one of the "lucky" few that WASN'T experiencing issues related to the XR500 and "internet drops". The only issue I was having involved my Nest Cam disconnecting from the XR500 and reconnecting after a few seconds. This issue only seemed to happen during the late evening hours, or early morning hours.
Fast forward to a few weeks ago. I received the latest beta firmware to try, in hopes of it solving the problem with my Nest Cam. It DID NOT resolve the issue with my Nest Cam disconnecting from the XR500, AND introduced a whole slew of other ISSUES.
About once a week, I notice wireless devices get disconnected from the internet. The modem (CM1000) and router (XR500) show no issues pointing to an internet issue with my home networking (all green lights on CM1000 / all white LED lights on XR500). After resetting the CM1000 and XR500, I get an orange blinking light LED internet light on the XR500. I performed another reset, waiting more than 20 minutes before turning on the CM1000 and XR500. The XR500 still showed an orange blinking LED light for internet.
I contacted my ISP. The technician directed me to unplug the modem and router for two mintues, while my modem was "reset" by the ISP technician. After powering up the modem and router, I still had an orange blinking LED light for internet. The ISP technican directed me to unplug ONLY the modem for two minutes, and leave the router powered on. After the modem powered up, the XR500 internet LED light was blinking white. BOO - BAMM........I'm back in business!
**COULD THIS BE WHAT MIGHT BE CAUSING THE PROBLEMS MOST ARE EXPERIENCING** >>>>> The ISP Technicain indicated that my XR500 wasn't showing connected a router (XR500). The ISP Technician indicated the IP addresses of two devices on my home network were blocking the XR500 from connecting to the CM1000 (not sure of technical term), and that the CM1000 was trying to use the IP addresses of two devices on my home network to establish a connection between the CM1000 and XR500. He indicated this issue was a problem with Linksys routers in past, and has seen it more recently with Netgear routers and modems as well. I sure hope this makes sense to at least one person, as I'm trying to remember exactly how he explained it.
This morning I woke up to my iPhone X not working via WiFi on my home network. Again, there were no indciations that the internet WASN'T working (no trouble lights on CM1000 or XR500). After power cycling the modem and router for almost 20 minutes, the XR500 showed an orange blinking LED interenet light. After power cycling the modem for five minutes, the XR500 internet LED light was blinking white. BOO - BAMM........I'm back in business AGAIN!
For me, the latest BETA firmware release presented this issue and hasn't resolved the issue with my Nest Cam. The latest OFFICIAL firmware release was solid and I never had an issue with XR500 dropping internet. I'm going back the the latest OFFICIAL firmware release in hopes it resovles the problem I described above.
I'm wondering if anyone else can try the following when they notice the XR500 drop internet:
1. Power cycle modem ONLY (keep XR500 powered on) for about five minutes. Once the power cycle is complete, check for internet.
Hopefully this post can help with troubleshooting / bugs related to the XR500.
Oct 25, 2018Guru - Experienced User
Are you client devices usnig Dynamic or Reserved IP addresses? If Dynamic, try reserved for ALL of your devices.
This is something i'm not seeing on my 450. As of yet.
- B1ggSh00t3rOct 25, 2018Apprentice
ALL devices are using 'Reserved IP' addresses.
- FURRYe38Oct 25, 2018Guru - Experienced User
Ok, Remove ALL reservations and let them be Dynamic. Same thing happens?
- Nate84Oct 26, 2018AspirantHi I just set this router up a few weeks ago and I’m having issues now with my wired and wireless devices all dropping for a few minutes. I switched back to my original router and not having any issues. I’m just wondering if someone could assist and what information you’d need? Thanks!
- Netduma-FraserOct 26, 2018NetDuma PartnerHi Nate, I've sent you a PM
