Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Oct 25, 2018Guru - Experienced User
Ok, Remove ALL reservations and let them be Dynamic. Same thing happens?
B1ggSh00t3r wrote:
ALL devices are using 'Reserved IP' addresses.
Nate84
Oct 26, 2018Aspirant
Hi I just set this router up a few weeks ago and I’m having issues now with my wired and wireless devices all dropping for a few minutes. I switched back to my original router and not having any issues. I’m just wondering if someone could assist and what information you’d need? Thanks!
- Netduma-FraserOct 26, 2018NetDuma PartnerHi Nate, I've sent you a PM
