Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
raizor
Oct 28, 2018Initiate
I would like to try the beta firmware please.
I'm also getting disconnects. Sometimes it's only the LAN ports that stop functioning, other times it's LAN and wifi that goes down. Both are solved with a reboot until it reoccurs. It happens randomly...sometimes it lasts a week without a disconnect, and sometimes it'll happen multiple times per day.
Thanks
Netduma-Fraser
Oct 28, 2018NetDuma Partner
Sent you a PM
- Shaun0300Oct 30, 2018Aspirant
Hi i recently got in youch about my netgear xr500 lan ports being disconnected in the morning or when ive not been home for some time i have installed the beta firmware you sent me and for a few days it worked but unfortunately when i got home tonight it had done the same thing again whats my next step thanks in advance shaun
- Netduma-FraserOct 30, 2018NetDuma PartnerHi Shaun, sorry to hear that. I have already given feedback to Netgear that it hasn't resolved everyones issues so I'm waiting to hear back about another fix. Thanks for your patience I know its frustrating
- CooLRuNNinGSOct 30, 2018TutorI still have the same issues unfortunately. Leaving my Xbox one x in instant on mode with a wired connection causes the router to drop connection. The only way to re-establish a connection is by rebooting the router. Tried the new firmware but still have the same issues. I’ve spent so much time resetting and tampering with options but nothing seems to work. I’ve never had this issue prior to buying the XR500. Extremely disappointed with this router and am tempted to sell it and replace with another brand. Any help is greatly appreciated as selling it really is a last resort.
