Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
MCasteel87
Nov 17, 2018Aspirant
I am having the same issue with my Xr700 I have had this since it came out and I'm constantly getting kicked out of Destiny 2 on Xbox one x and am only getting 110 mbps on speed tests I should be getting over 400. We have tried port forwarding doesn't help at all.
Netduma-Fraser
Nov 18, 2018NetDuma Partner
Are all your devices just going down or just being disconnected from Destiny? If latter its not the same issue. You need to use the Destiny Geo-Filter profile to prevent booting. Also are you testing the speeds on the console? They can be inaccurate best to use a wired PC for better results.
- CajunbullNov 18, 2018AspirantNot playing Destiny, but yes it disconnects everything including wireless.
- Netduma-FraserNov 18, 2018NetDuma PartnerI was responding to Casteel but I've sent you a PM Cajun
- MCasteel87Nov 18, 2018AspirantThe drops are happening in every game only a lot more noticeable in Destiny. How do I enable the destiny geo filter this is the first time I have ever heard of that. Also.on my xbox one x the speed tests are always accurate and yes it is wired. I don't know why people keep saying speed tests on consoles are inaccurate they never are for me always the same readings as my pc when hard wired. On ps4 though they will always be inaccurate because they cap your speed.
- Danny80916Nov 18, 2018Luminary
under geo filter next to km away there is a profile button click it and destiny is in the list.
- MCasteel87Nov 18, 2018AspirantWhat exactly does the destiny profile do? Can you select multiple games or one at a time?
I think it just makes a diffrent search area
- Netduma-FraserNov 18, 2018NetDuma PartnerDanny, not a new firmware than the one you mentioned.
Smith sent you a PM with that firmware.
Casteel, as above just changes radius and for Destiny disables strict mode. Don't need to use a profile to play a game, just gives our recommended radius - Danny80916Nov 18, 2018Luminary
alright, Thank you I am still having problems i have restored and reflashed firmware.
- BobisbadatNov 18, 2018Aspirant
After trying the beta firmware XR500 V2.3.2.32-802-3-az-1009 over the weekend, the issue persists Netduma-Fraser . ~Once per evening, usually during our heavier usage time, we lose iternet connectivity with no change to online status of router nor modem. A reboot resolves the issue but only for another day or so.
- Netduma_JackNov 19, 2018NetDuma Partner
Hi Bob - sorry to hear it is continuing. There should hopefully be a new build soon. Have you been able to raise a Case ID with NETGEAR? If not, I recommend you do this as they might be able to send you another beta firmware to help with your problem.
- BobisbadatNov 24, 2018Aspirant
Yes I have an open ticket with them that so far has had no response beyond a couple of blank "bumps". Do you know if there is any validity to this "bad modem" informtion being sent around? Like is there some form of compatibility issue or something I can be doing to help narrow down the issue for a fix? I bought this router because when it works, it works reall well, and the support I saw y'all giving on here was the sealing deal. I want to help in any way I can, however I'm also nearing my return date for the router. I want to be able to replace it if there is't a solution in sight.
- spdsk8raceNov 24, 2018ApprenticeHaving constant lease renewals, dropped internet connections, or speeds not above 50 mbps until I reboot the router, after turning off all Geo filter and qos, I started to get back to my normal speeds off 800-900 mbps, but then my $300+ router might as well be a $50 dollar. Currently running a beta version of the firmware, already factory reset and still experiencing the same issue. The beta firmware did however fix the wifi from randomly dropping everything, but I don't know if it's any better.
- Danny80916Nov 24, 2018Luminary
I feel ya , I have had those same problems for months. I can't stream 4k movies on sony devices with QoS on.
- MossbergNov 25, 2018TutorWelp, the firmware did NOT fix the issue.
When I first bought the router, it was fine. It was not noticeably dropping connections. Now, it’s all the time. It stays connected for 24hrs and afterwards, it’s toast.
What are the remaining options? Can I downgrade to an older firmware? Is there a warranty? I just bought it in September.
It’s been miserable—especially having a “smart” home. When I leave the house and my connection goes out, I can’t connect to anything.
In retrospect, I use to have a connection that was online 24/7; 365 (except for inclement weather or outside incident). I would like to go back to that but the thought of wasting $250+ for a device that DOES NOT WORK after such a short period of time. - ngearftardNov 26, 2018Luminary
Mossberg :
Posting back here as promised to let you know the idea posted in #625 (reserving an in-house IP address for the camera) is working for me. The camera no longer loses the connection for more than a few seconds every night. Can't see why this wouldn't work with multiple cameras/devices and their respective 192.168.1.2XX reserved IP addresses (where XX is in the range, 01-50).
What is modem make/model? Reason for question is I want to compare it to a list of modems with known connectivity issues (XR500 magnifies these). Feel free to PM if that's better.
- Netduma_JackNov 26, 2018NetDuma Partner
Hi everyone - I'm going to send this thread link to a NETGEAR project manager to see if there is a newer firmware they can share or if they're aware of any current reason why you might be having issues.
- MossbergNov 26, 2018Tutor
My issue isn't isolated to just the cameras going out. It's EVERYTHING that's connected to the router going out. I wish it was just the cameras, or just the google home, or just my XBOX...it's everything. SMH.
- smitheramNov 27, 2018Guide
Hi,
Completly fed up with NETGEAR support, dont seem to care once they have sold the router. I had a Asus RT-AC88U which if I had problems, could share with the development team and a beta firmware was provided to try if neccessary. Netduma have been fantastic but have there hands tied by NETGEAR who fail to see that the router at the moment is not fit for sale and like a lot of routers at the moment the consumer becomes the guinea pig after splashing out the hard earned cash. Netgear Support is pointless as they do not listen but read of the same hymn sheet. I am going to wait to see if a firmware release happens this november but with 4 days to go I am not holding out much hope and considering another router option.
- spdsk8raceNov 28, 2018Apprenticengearftard
Sorry for the delay, been busy at work with Black Friday,
Make: Pace/Arris
Model: 5268ac
Att UVerse gigapower - ngearftardNov 28, 2018Luminary
I hear you; not doing this for a living either. Broadcom chipset, so it's probably not the modem. With modem ruled out, try this:
Pick one device that's dropping out, and give it a fixed in-house IP address (see last paragraph of Message #625 in this thread for how to do this). If you don't already know: you can copy and paste the device's MAC address from the Device Manager page of the UI. Give it 24 hours. If it works, do the same for all the devices that are dropping. This fixed a wifi camera that was dropping for me.
- Netduma_JackNov 29, 2018NetDuma Partner
smitheram - I can't give an exact ETA, but NETGEAR are working hard to release the next firmware for the XR500. Hopefully it won't be a much longer wait.
- MossbergNov 29, 2018TutorHmm? I turned off “instant on” on the Xbox One(I thought it was already off) and have gone TWO DAYS without any drops! Hmm?
- Netduma-FraserNov 29, 2018NetDuma PartnerThat's what we think the issue is related to so thanks for confirming that
- MossbergNov 30, 2018TutorYup...I may be in the clear. Another FULL day of zero drops since turning that feature off.
