Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma_Jack
Dec 03, 2018NetDuma Partner
Hi everyone - sorry to hear you are experiencing dropouts. I wanted to just repost some known problems/fixes as this thread is quite long now so could be lost:
- NETGEAR have made a hotfix firmware that fixes one cause for dropouts - either ourselves or NETGEAR can private message you the firmware
- There is a known issue with Xbox One when Instant Mode is enabled. This effects a very small % of users, but can cause you to lose ethernet connection to your Xbox when you restart. NETGEAR are looking into a fix for this. The workaround is to disable Instant Mode on your Xbox
If you have installed the hotfix firmware and you have disabled Instant Mode on your Xbox One (or you do not own an Xbox One then please post here with as much information as possible about your dropouts. One thing to always check is whether it's the router that's the cause or if your entire Internet has gone down. Simplest way to do this is to connect to your Internet Provider's modem after a dropout and see if you can get Internet through it.
JonQwest - I'll PM you the hotfix firmware now.
chaosminionx
Dec 03, 2018Aspirant
Could I also get the firmware PM'd to me? Thank you!
- smitheramDec 03, 2018GuideIs the hotfix more recent than beta 2.3.2.3280231009?
- Netduma_JackDec 03, 2018NetDuma Partner
- T-Morgan-911Dec 03, 2018Aspirant
Can I please get the fix as well
