Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
smitheram
Dec 03, 2018Guide
Is the hotfix more recent than beta 2.3.2.3280231009?
Netduma_Jack
Dec 03, 2018NetDuma Partner
- T-Morgan-911Dec 03, 2018Aspirant
Can I please get the fix as well
- Danny80916Dec 03, 2018Luminary
I would like the hotfix also.
- Bulldaw6Dec 11, 2018GuideHelp, have instant on off. No internet wired or wireless. Did 3 reboots, no internet. Bypassed the router and have internet :(
- Netduma-FraserDec 11, 2018NetDuma PartnerDo a factory reset using the button in the back of the router. Hold for 30 seconds and let go, then connect to interface and go through the setup wizard. Are you on the beta firmware?
- Bulldaw6Dec 12, 2018Guide
I got super frustrated and went outside for a bit, i came back in and went through the "setup process" though the router without a factory reset. It did restorre my internet, but the reason i rebooted the router in the first place is becasue im getting half the speeds i pay for. I plug ethernet in pc directly and i get the correct speeds. Im beyond frustrated with this router, the cons are starting to outweigh the pros. V2.3.2.32 is the firware im on, havent had any internet drops drops since i cut off instant on while using this firware, but today with my internet being completely down during "rush hour" for my home was unaceptable. Still not sure what to do about getting half speeds.
